J D Model M stuck motor
Rick
01-04-2004 03:25:40
I am going to look at a 49 M for sale. I am told the motor is stuck. What is the most common cause of a stuck motor on a M? What other things should I be looking for? With everything else looking in good shape, how much would you give for it?
Farmered
01-04-2004 04:15:14
 Re: J D Model M stuck motor in reply to Rick, 01-04-2004 03:25:40
Most common cause is outdoor storage with an uncovered exhaust. Around here it would be worth a couple of big ones. $500 less with the stuck engine. Try soaking a couple of weeks with rubbing alcohol in the spark plug holes. I've heard that turpentine works too. You can make an adapter from an old spark plug by welding on a 1/8
NPT coupling. Screw in a grease zerk. You can exert about 3000 psi with your grease gun. You have to make sure the valves are closed. Take off the rocker arm shaft or in the case of a valve- in-block (L head) you may have to remove the camshaft gear. Best to take off the bearing caps and rotate the crank out of the way so you won't bend the crank if more than one piston is stuck. You will end up with a great gob of grease in the engine but it is 99% sure of gettin' it loosened up. Good luck. Alternate method: use a Porto-Power
hand hydraulic pump with that spark plug adapter.
If you like, 14mm and 18mm to 1/4 NPT adapters are available at your auto parts store. I believe they are made by Ken-Tool or some similar supplier. Ed
Dan
01-04-2004 11:04:36
 Re: Re: J D Model M stuck motor in reply to Farmered, 01-04-2004 04:15:14
If it set for a long time and now is stuck I would go with the uncovered exhaust. It seems like the ones with lay down cylinders will stick easily in not too long a time but the vertical ones don't seem to so much. If it was run often and suddenly stuck, I would think probably a spun rod bearing. Make sure tractor is stuck and not just the starter jammed.
Farmered
01-04-2004 04:30:18
Those adapters are called "air holds" and are used to hold the valves up with compressed air so you can change valve springs, seals, etc. without removing the head. Ed
could it be Rick
01-04-2004 04:28:44
thanks for the reply. What about the possibility of a broken piston, rod, or other internal parts causing it to be "stuck". Of course I know it is possible, but is it likely on this engine? Is there and internal "weak link" on this engine. What about block cracks- if there is one where is it likely to be? I am going to look this tractor over late this morning and any tips are appreciated.
Farmered
01-04-2004 04:44:09
 Re: Re: Re: J D Model M stuck motor in reply to could it be Rick, 01-04-2004 04:28:44
All those things are a remote possibility. Add to them a spun bearing caused by insufficient lubrication. I have not heard of an inherant weakness in that little engine. An external crack will be obvious on the side of the block but a cracked webb between the cylinders probably won't show up externally. Now if it was an AC WD or WD-45 I would guarantee that the block would be cracked if the temperature went below 28 degrees with water in it. ED
Farmered
01-04-2004 05:05:24
 Re: Re: Re: Re: J D Model M stuck motor in reply to Farmered, 01-04-2004 04:44:09
By the way, what are you doing up so early? Or havn't you gone to bed yet? Ed
early riser- Rick
01-04-2004 05:14:00
 Re: Re: Re: Re: Re: J D Model M stuck motor in reply to Farmered, 01-04-2004 05:05:24
Altho I dont earn a living as a farmer/rancher i still get up early every day-around 5. of course i am usually in bed by 8 or 9.
I have never owned worked on JD's so any tips for checking out this machine is a real help. thansk
Farmered
01-04-2004 05:48:46
 Re: Re: Re: Re: Re: Re: J D Model M stuck motor in reply to early riser- Rick, 01-04-2004 05:14:00
Well, when you count the sparkies, you will come up either two or four short, depending on what you are used to. Other than that it works pretty much the same except it is green which makes it easier to loose in the grass. You can pretty much tell by looking if it has had TLC or has been run hard and put away wet (or not put away) or even beaten to death. Nice talking to you! Ed
