720 LP trans IT WORKS/Yea
Ben.So.Tex
02-10-2003 18:09:00
Well I put oil in the 720 today,, the tractor fired off and I tried out the trans and it all shifted and sounded good Thanks to all you good poeple out there,,,,,Now I have to work on the power steering it does not want to steer/ real hard,, I did notice that while it was running the steering wheel was turning to the right all by itself, What could that be? Thanks Ben
Clooney
02-10-2003 18:31:02
 Re: 720 LP trans IT WORKS/Yea in reply to Ben.So.Tex, 02-10-2003 18:09:00
third party image
Ben, try removing the flow control valve cap & turning the valve in a little to increase flow. ~To stop the wheel from turning by itself, loosen the 4 bolts shown & tap the steering valve in direction shown until the force to turn the steering wheel is the same in both directions.
~If the above doesn't help you will need to do some further steering pressure tests & adjustments & a manual at that point would be a good investment...
Ben.So.Tex
02-12-2003 04:01:45
 Re: Re: 720 LP trans IT WORKS/Yea in reply to Clooney, 02-10-2003 18:31:02
Thanks Clooney,, I will proable try to check it out thurday or friday to see if I can get it to work,, Ben
