Hi Denny, a first thought is the float level. If its way too low, it can idle okay but starve for fuel under load. Another thought is a restricted fuel flow problem, either in the carb or from the tank. It may have plenty fuel if at idle, but not when a load or high RPM calls for more fuel. 1. If you open the carbs bottom drain cock, does gas flow continous about 1/16 stream?? 2. If not, if you remove the fuel line from the carb, does gas flow its internal thickness continuous????? 3. If both those tests pass and the float level is okay, does a slight choke make her run okay????? ?? 4. Have you removed the air cleaner bottom to insure no clogs there???? You say you adjusted the load needle, (out at least a turn I assume and more???), does she ever richen and black smoke if its way out????? If none of that helps, Im thinking a clogged carb circuit of nozzle maybe, so if you have good flow both places and load needle adjustments dont help, and youre sure its a carb not an ignition problem or flow from the tank problem and you have good clean water free gas, I would purchase a carb kit and disasemble her and clean all passages and the nozzle and check the float and let us know what happens. Good Luck n God Bless. Ol John T Nordhoff in Indiana
