JD 60 grill
moline
02-09-2003 19:29:09
I am trying to remove the front grill on my 60 so that I can service the power steering.I removed the 4 bolts holding the grill to the hood and also the 4 bolts with springs on them from the bottom.The grill still wont budge!What am I doing wrong or what am I missing?Any help would be greatly appreciated.Thanks in advance.
moline
02-11-2003 18:52:58
 Re: JD 60 grill in reply to moline, 02-09-2003 19:29:09
I am embarrassed to tell you guys this but I thought the grill center stayed on the tractor just like my A.You guessed it!The two bolts right in front of me about eye height that were holding on a cullivator bracket.I removed those and the grill came right off.Oh well I seem to remember lessons better when I learn them the hard way. Thanks for the help guys,I really appreciate it. Moline
AlbertoV05
02-11-2003 11:28:45
Moline,
Don't forget the two bolts on top that attach the grille and hood; also two more bolt/nut combinations (one on each side) where the grille and hood bolt together.
Al in Iowa
Mike J
02-10-2003 07:53:00
Are there any bolts in the front on the upright post that piece come off with it if there arn't the only thing left is the little pegs it sits on did yours have the little pipes in the middle of the springs if it did then I bet they are full of dirt and rusty and you will the have to put a punch on the bolts and tap them up threw the pipes
