JD 4200 Plow.
DEM66
01-03-2004 17:33:08
We bought a JD 4200 plow 2 years ago and plowed 40 acres a year for the past two years. I grew up on a ranch in the mountains of Colorado and never even touched a plow until we bought this one. We are going to need to plow 100 acres with it this next year so I need to get it adjusted and working better. The biggest problem is it gets stuck in the middle when we spin it. Has anybody had this problem or have ideas on how to fix it? Also does anybody know a good source on how to adjust a plow? This is a 4 - 18" bottom plow and we are pulling it with an IH 5488 MFWD Tractor. I know I can hear it now from some of you guys "the problems not the plow it's the red tractor" LOL.
Thanks,
Dan
Lloyd
01-04-2004 12:06:24
 Re: JD 4200 Plow. in reply to DEM66, 01-03-2004 17:33:08
Hey Dan My Dad bought one new in the early 70's. Does yours still have the rod that switches the hydo valve on the plow when you flip it. This changes to oil flow to complete the flip. Most are broken off due to wear in the tube. I ran mine for years without it. Set your hydralics for the fastest speed you can get. Move the lever to start the roll and just as the plow gets to the center push the lever in the opposite direction. To set the plow measure the lower links and set them exackly the same. If the two sides do not match in the field then use the stop bolts that are on each side of the plow to fine tune it. you will also have to shorten or lengthen the center link to level fore and aft and set the guauge wheel for the depth you want. If the plow is not warped it should plow level. Hope this helps Lloyd
DEM66
01-04-2004 13:46:08
 Re: Re: JD 4200 Plow. in reply to Lloyd, 01-04-2004 12:06:24
Lloyd,
Yes the rod is there in fact the plow will spin clear over once in awhile. I'm thinking that maybe the problem is caused by too much slop in the hole where the cylinder mounts to the plow. Do you think that could cause it? I understand that you use the lower links, the stops, and the center link to adjust the plow but getting it set right is not as easy as it sounds. It seems in order to get the back of the plow down far enough it then won't lift high enough to spin. Do you still have a manual and do you know what to set the tires at on the tractor? We got it to plow ok this past year but it left the ground a little more uneven than I would like.
Thanks,
Dan
Lloyd
01-04-2004 16:11:50
 Re: Re: Re: JD 4200 Plow. in reply to DEM66, 01-04-2004 13:46:08
Hey Dan
I am not familiar with IH tractors so i don't know thier hydralic capabilities. That plow has to swing pretty fast for the momentum to carry it on over. Keeping the pivot point well greased helps. Yes the slop will hurt as it throws the center off. You have to use the guauge wheel as a pivot point to get the depth set. Instead of lengthing the top link raise the guauge wheel and use the lift to pivot the plow on the wheel. I am very familiar with the guauge wheel hitting the ground. When I raised the plow on the end I either backed the tractor so the wheel would swing in the furrow or turn around and drop the front wheel into the furrow before flipping the plow.Yes I think I still have the manual. We had our tractor set on 38 inch rows but friends had theirs set on 36 inch rows. You also can't run the plow in a stabilized position. It has to be free to move or it will drag the tractor around in the furrow. Hope this helps Lloyd
DEM66
01-04-2004 17:37:50
 Re: Re: Re: Re: JD 4200 Plow. in reply to Lloyd, 01-04-2004 16:11:50
Lloyd,
Thanks for the information. Our 5488 is a 185HP tractor it has good momentum when it spins. I think we just loose that momentum in the slopped out hole where the cylinder mounts. Using the guauge wheel to pivot the plow on makes sense. We will give that a try this coming March when we start to plow.
Thanks again,
Dan
