CLOONEY, THANKS FOR THE HELP ON BR WHEEL LOCK-UP
GARY
02-09-2003 13:16:11
Clooney, you responded to my problem with my 38 BR. The left rear wheel would lock-up when in reverse sometimes and never in a forward gear. You replied that it was probably in the brakes and sure enough that was where the problem was. I'm not sure of all the mechanics in the rear-end but the right brake had slipped off the cam causing it to bind in the drum. Not sure why the right brake locking up caused the left wheel to lock-up though? Ordered a new cam and tightened up the roller's with another washer and haven't had any problem's since. Thanks for the advice again as I was thinking it might be someting worse.
Clooney
02-09-2003 14:04:28
 Re: CLOONEY, THANKS FOR THE HELP ON BR WHEEL LOCK-UP in reply to GARY, 02-09-2003 13:16:11
Gary, glad you found the problem & wasn't inside the trans.....
