Merle, the fuel sucking out of the hose at full throttle is normal. Where was the fuel level in the hose when run at idle? Try running it with the air cleaner disconnected to see if that makes a difference in the fuel level in the hose & the tractor operation... ~If you are losing spark when it quits you have an ignition problem. Are you sure it's a Wico X mag & not a Wico XH distributor? They look almost the same. Does the mag snap when the engine is turned over slowly? If not maybe it's a distributor. The Wico distributor will have a little oblong cover on the front with a wire stud in the cover.. ~If it is in fact a Wico X mag, start by making sure there is no external wire attached to it [if there is, REMOVE IT],,,if it had a wire & removing it doesn't change your problem you will need to try a few things.... Try a new condenser [if the condenser is shorting to ground or going open after a little use it will shut the mag down],,,make sure the points are set to .015",,,make sure all the internal wire connections are tight & not corroded,,,if it still acts up, try a new coil [maybe it is going open hot]...Are the plug wires solid metal core & not automotive TVRS [carbon core]? If not change them... ~If you can't find anything wrong with the mag you might have to swap a mag from another tractor just to see if it really is a mag problem. If a different mag eliminates the problem you know for sure you have a mag problem, if it doesn't you have other problems like fuel/carb.. ~If you can't borrow a mag for a test you can take an old plug wire & cut it about 4" from the spark plug end, then strip back the outer insulation for about 1/4" on each piece to expose the inner metal wire, then find a 1-1/2" to 2" long piece of clear plastic hose that will just push over the plug wire ends, then push both the cut plug wire ends into the tubing until the wire ends are about 1/8" to 3/16" apart. You can then install that wire on the tractor & watch the spark in action with the engine running [will need a dark place to do this in]. With that wire you will be able to see if the spark quits first or the engine quits before the spark does...
