Dear Mr. Turner, the same set of points and condensor and coil fires both cylinders, so you might want to look at plugs, wires (use wire not carbon suppressor types) distributor cap and rotor for any problems like a bad wire, a fouled plug, a crack or carbon path in the cap. Its easy to substitute wires and plugs from one side to the other to see if that makes any difference. I would remove the plugs and with the wires still attached but their case grounded, observe if each has about an equal good blue spark. If not, swap sides and wires etc to isolate a bad wire or plug. I would inspect the points and see if the gap is about the same on each high cam lobe and that they are NOT pitted, burned, or oxidized. If any, replace them. You might even first try and open their gap a bit (like 0.002 or more than they were) (maybe bearings or lobes are worn uneven) to see if that helps. 0.016 to 0.017 if mag and 0.020 to 0.024 if distributor. I would see if the side that fouls plugs has about equal compression with the other. If either side has a flat black sooty looking plug or a wet shiny residue more than the other, I would first at least install a new plug there. If they havent been replaced in a long while, I would try a fresh set of plugs and clean and re gap or just install new points and condensor, assuming the wires are in good shape, and clean and inspect teh cap and see if that helps and if not, post back with what you found and what you did so far. One side fires stronger at idle anyway, but it shouldnt miss out as you described. Another problem may be a condensor, but I would suspect a plug or wire or points first. You may also want to check if the choke is workign properly (butterfly plate really closes) and if richening the power or idle jets helps matters. Does choking durign that period help things????? ????? ?? If so, post back. Good Luck n God Bless, let us know Ol John T Nordhoff in Indiana
