720 Rear end oil 80-90GL5 or90GL1
Ben.So,Tex
02-08-2003 12:14:36
I hope to my 720lp running today,but I went to get some 140 wt. rear end oil and the dealer was out, My question is,What does the GL stand for in the heavey oil? Do you think 90 wt will work OK for me, If I can;t get the 140 wt... Thanks Ben
Clooney
02-08-2003 13:37:54
 Re: 720 Rear end oil 80-90GL5 or90GL1 in reply to Ben.So,Tex, 02-08-2003 12:14:36
Ben, GL stands for "Gear Lube". There is a number after the GL that will read like GL-1 through about GL-7. The lube you want is GL-1, but GL-4 or 5 will also work. 90 weight is the gear oil that was called for to use in your tractor originally but some people use a 140 weight in older worn tractors in warm climates.
~If you have a Wall-Mart near you might try there, in my part of the country Wall-Mart carries a GL-1, 90 weight gear oil in 5 gallon pails for about $20.00.....
Ben.So.Tex
02-08-2003 14:21:08
 Re: Re: 720 Rear end oil 80-90GL5 or90GL1 in reply to Clooney, 02-08-2003 13:37:54
Thanks Coolney,, I will stop in at the local wal mart tommorow and get some.. Then I can try out the tranmission replacement job I did..
