4230 JD load control bushings.
Randy
01-03-2004 16:29:04
can anyone tell me how to get load control bushings out of a 4230 jd.
Thank you.
Jim B
01-04-2004 05:03:34
 Re: 4230 JD load control bushings. in reply to Randy, 01-03-2004 16:29:04
Randy,drain transmission oil,support cast piece with a jack that 3pt.arms attach to,take plugs out of both ends of l/c shaft.Tap out L/C shaft,lower cast piece and use a longer rod to drive bushings out from each side.Don't replace bushings unless they are worn as replacing them too often will make hole in trans.housing enlarge.Another choice instead of jack to hold up cast piece is a comealong.Good luck and be careful.Removing 3pt. arms can lighten cast piece.Jim B
806
01-04-2004 07:06:04
 Re: Re: 4230 JD load control bushings. in reply to Jim B, 01-04-2004 05:03:34
Would be good idea to replace the pin in the yoke, The pin that attaches the yoke to the transmission housing also allows movement. Helps to remove any play due to wearing of the pin.
