JD 420 3 point seal
Richard
02-07-2003 07:06:36
What kind of seal is on the shaft coming out of the valve that controls the 3 pt. lift & how is it changed? Thanks
Wayne in Tn.
02-07-2003 07:23:21
 Re: JD 420 3 point seal in reply to Richard, 02-07-2003 07:06:36
Richard, Im' taking for granted you have the Dual Powertrol, with two levers. There will be two shafts coming out of the front housing, each has a seal. This is where it leaks underneath the control levers. The complete unit has to be dissasembled in order to replace those small seals. The levers and quadrant have to be removed. The shafts have to be unhooked from the inside to remove. To tackle this job, it is best to have the service and parts manual.
Wayne in Tn.
02-07-2003 09:40:25
 Re: Re: JD 420 3 point seal in reply to Wayne in Tn., 02-07-2003 07:23:21
Sorry, I meant to say Dual Touch-O-Matic, not Powertrol.....
