40carb
Doug
01-03-2004 15:03:06
Have a 40 with tsx530 carb put throttle shaft and bushing, complete kit and run wire through all the passages still won't idle , Keeps on surgen until fast idle. Makes no differece where idle screw in or out of tractor, set the float from 1/2" to 1/4" RUNS fine over fast Idle, can't find any vacum leaks. THANKS FOR ANY HELP DOUG
Wayne in Tn.
01-04-2004 08:35:43
 Re: 40carb in reply to Doug, 01-03-2004 15:03:06
Doug, I was afraid of that, on the main jet. I don't know what its specific function is, but from expierence, I have had them not idle or run correct until this is clean. I have had the govenor "hunt" for the correct idle and everyone said the govenor was bad. But I have never actually found a bad govenor, it was always a carb. problem. I can just about guarantee if you will get that main jet out, in pieces or whatever it takes, install a new one, and you will think you have a brand new carb. It will restore the (adjustability) to the carb. Robert's has that jet in stock.
Clooney
01-04-2004 05:52:07
Doug, if it runs good at high speeds that pretty well says the load part of the system is at least operating..
~I still suspect the idle system as the cause of your problem.. Did you get the two idle orifices cleaned out?... Do as Duane said & spray some carb cleaner or brake clean into the idle passage & look for the spray to come out the idle orifices.
~You should also check the economizer passage but a plugged economizer usually makes them go rich...
~There is a small idle fuel passage in the lower carb body that runs from the load channel up through the lower casting & to the upper idle passage, make sure that passage is open & that the cover gasket isn't blocking that hole.. [the idle & load system both use the same fuel supply from the base].. Maybe by not pulling that load jet you didn't get the bottom of the idle fuel supply passage opened up enough. Back spray carb cleaner back through that lower idle fuel passage & make sure it comes out the load passage...
~I'm sure you already checked this but just a reminder: Make sure the new & old carb top gasket have the same holes punched in them.. If one of those holes doesn't match, that carb will never meter correctly.
~One last thing.. Does the throttle plate fit the bore correctly [was it centered?] & is it worn excessively on the ends? If air gets around the ends of that throttle plate it will cause all kinds of low throttle opening metering problems..
~I have a pretty good picture of that carb in a cut-away view,, let me know if you need it...
~Maybe Duane or Wayne can add some more here..... ..
[email protected]
Clooney
01-04-2004 05:55:34
 Re: Re: 40carb in reply to Clooney , 01-04-2004 05:52:07
Sorry Doug, this should have gone under your follow up post to me below..
Duane Larson
01-03-2004 15:49:45
Doug,
Did you remove the idle jet and clean the passage behind it? Remove the carb top, turn it over, and you will see the brass jet. Be careful when removing it, as if the jet edges are forced outward by turning the jet with a screwdriver, they will interfere with the casting and the jet will be even harder to remove. If it is stuck, clean everything well, and use heat to heat the idle jet till the heating flames have a green tinge. Let it cool completely, and the jet should come out. Use a can of spray carb cleaner to spray behind the jet and look for spray coming out of the idle passages in the main throat.
Your carb also has an economizer jet, which is located to the left of the idle jet, but deep in a hole. It affects operation primarily at mid-range speeds and throttle.
The load circuit functions when the tractor is under load, otherwise, operation is controlled primarily by the idle circuit.
Clooney
01-03-2004 15:48:40
Doug, it sounds like you missed something in the idle passage [did you remove the idle jet?]... If not I'm betting you didn't get the idle passage above the idle jet clean enough.. Either that or you still have a plugged primary or secondary [or both] idle orifice in the upper carb casting..
~In any case it sure sounds idle passage or idle orifice related,, especially if the idle air screw has no effect on the idle..
[email protected]
DOUG
01-04-2004 00:51:36
 Re: Re: 40carb in reply to Clooney , 01-03-2004 15:48:40
Yes I had both of those idle jets out three times and boiled out twice run wire the only thing is I couldn't get that main jet out in middle off lower carb. I heated, small vicegrips on top but screw driver slot bad in bottom. Thought that was more for high speed anyhow. THANKS DOUG
Clooney
01-04-2004 05:53:52
 Re: Re: Re: 40carb in reply to DOUG, 01-04-2004 00:51:36
[email protected]
Wayne in Tn.
01-03-2004 15:14:11
Doug, did you remove the (main jet)? This is the brass tube that sticks up in the throat of the carb. It has rows of tiny holes running the length of it, that must be open and clean. You have to remove the power screw in the bottom of the carb, then the main jet screws out with a flat screwdriver. Sometimes it takes heat to get them out, and sometimes, I have had to destroy them and get them out in pieces. If this happens, any of the carb rebuilders have new ones for around $25
