180 Degree Thermostat for Model 60
AlbertoV05
02-05-2003 18:53:40
Anybody have a 180 degree thermostat for a Model 60 they want to part with? I need Deere #AA5750R
Thanks
Al in Iowa
Tom in Mo.
02-06-2003 15:43:29
 Re: 180 Degree Thermostat for Model 60 in reply to AlbertoV05, 02-05-2003 18:53:40
I have read the replies here and thought I should throw this in. The reason the crossover T-stats are smaller MAY be that they are to be installed on the end of the casting where the hose attaches on its way to the radiator. The reason I say this is because that is the way the Ferguson (1954 Continental) engine is meant to be installed. The T-stat is the same diameter as the hose inside diameter and rests against the engine pump casting actually in the hose itself. Make sense? Just something to consider.
Steve - IN
02-05-2003 19:36:33
Al,
Good luck in finding one. They're not too plentiful. Meantime a piece of green tarp with eyelets on the corners can be bungee corded over the front screen in about 1 minute. And if you're not using your 60 that day you can switch the tarp to another tractor in about 2 minutes.
These shortcuts picked up from Dads and Grand Dads who farmed during the Depression die hard.
Steve
AlbertoV05
02-06-2003 04:06:47
 Re: Re: 180 Degree Thermostat for Model 60 in reply to Steve - IN, 02-05-2003 19:36:33
Ain't that the truth, Steve?!
I've tried every parts house in the county to try and get it crossed (i.e. Gates/Stant, NAPA, etc.). They all list a cross, but most are WAY to small in diameter - I darn near dropped the first one right into the block!!! The model Stant has actually was the right diameter but the flange was nearly 1/4" thick; there would be no way that I could tighten down the thermostat housing!
And of course 'Ma Deere only wants $105.16 for a new one.
The tarp/cardboard sounds better all the time!
I've got a functioning 160 degree one in there now and it looks like it's going to stay there!
Al in Iowa
Clooney
02-06-2003 07:58:55
 Re: Re: Re: 180 Degree Thermostat for Model 60 in reply to AlbertoV05, 02-06-2003 04:06:47
AlbertoV05, if you have a functioning 160� stat in there now it should be adjustable to increase the opening temp. Just put a piece of string in the closed T-stat trap door & hang the t-stat in a pot of water by the string, then while heating the pot on a stove, put a thermometer in the pot [caution: don't set the thermometer on the metal of the pot, or it will give a false reading]& watch the temp that the T-stat falls off the string. Just adjust until you get the opening temp you need. I haven't ever adjusted a 160� stat to 180� but you might get close.
AlbertoV05
02-06-2003 13:50:34
 Re: Re: Re: Re: 180 Degree Thermostat for Model 60 in reply to Clooney, 02-06-2003 07:58:55
OK, Clooney; I'm asking what is definately the dumbest question you've had today; and probably so far this year!!!
How do you adjust this thermostat to change the opening temp?
Thanks for the help
Al in Iowa
Clooney
02-06-2003 14:59:23
 Re: Re: Re: Re: Re: 180 Degree Thermostat for Model 60 in reply to AlbertoV05, 02-06-2003 13:50:34
Al, due to the differences in T-Stats I sent you an E-Mail with follow up picture.....
Steve - IN
02-06-2003 06:20:32
Al,
There may be a lot of wisdom in the tarp or cardboard. Getting a good result with the least amount of input is what farming is all about anyway.
-- about being a Hawkeye, I don't think Boilermakers like Burrey and Stan will mind a Hawkeye too much. Better not say much about Alford, though - he was an IU Hoosier. Talk about somebody like John Wooden - hall of fame as both a Purdue player, and obviously as a coach. That'll keep 'em happy.
take care,
Steve
