John t carbureator question
archie
02-05-2003 17:39:07
I have a 1953 john deere 40. I am going to rebuild the carbureator. i saw some time back you used air craft bits to clean out passages i think. if so where do you get them. i live in southwest mo. near springfield. thank you. Archie
Archie
02-06-2003 11:35:22
 Re: John t carbureator question in reply to archie, 02-05-2003 17:39:07
Thank you all very much for the information. i will get some bits and try my luck out. I will be back if i run into trouble. Thanks again Archie
John T
02-06-2003 05:34:35
I got mine from Roberts Carb Repair in Spencer Iowa (712) 262-5311 www.robertscarbrepair.com they were the extra long # 40 and # 53 used to drill out the passages to the right size located behind the 3 brass drill plugs on our A and B tractors single barrell carbs. His web page under a Technical Link has a pic of those carbs, but I dont think he has any 40 carb breakdowns. In addition, the other passages I use guitar strings or mig welding wire etc to clean them out. On the duplex carbs, the hardest part was removing the ball plugs to even first get to the passages, and thats a whole different carb and story from the single barrell units discussed above I used his bits on. Those bits are the correct size for the single barrell carbs (not sure if they are right or for use on any duplex passages??). I rebuilt my 620 duplex carb and removed the ball plugs to clean all its passages, but unless one were very experienced, I wouldnt try and talk them through that procedure here on the net. The roberts web site has a lot of info on both single and duplex carbs. Good Luck and God Bless Ol John T
cheg
02-05-2003 20:36:41
I just ordered 2 bits for my carb. Robert sent a diagram showing which passages usually plug. I was amazed at how much old rust came out when I ran the bits through the passages. I am a believer that a wire will not do the trick.
Randy
02-05-2003 18:10:45
roberts carburetor repair. 712-262-5311
