JD injection pump
david
02-02-2003 18:35:08
On my 4230 JD the injection pump wouldnt reponse till it got almost to O rpm. Had replaced the transfer pump,filter and got a good flow of fuel to the injection pump. I had the injection pump rebuilt at an Auth. pump rebuilder and It was a little better after I installed it but not enough to call it good. Did I get a bad rebuild or is something else wrong? The govenor is still REAL slow to respond. Timed acccording to JD dealer and still is like the gov. is sticking or is slow to respond. Any help is appreicated, Thanks , David
Gord
02-02-2003 21:28:28
 Re: JD injection pump in reply to david , 02-02-2003 18:35:08
Unfortunately, if the governor is slow to respond then usually it is the metering valve in the injection pump that is sticking or the vane pump inside the injection pump is not building enough pressure. It looks like the pump will have to be removed and repaired again.
