2520 Diesel Power
Brad
02-02-2003 13:44:11
Is there an easy way to increase the horsepower on a 2520 Diesel. Thanks, Brad TX
TB SCOTT
02-03-2003 13:50:14
 Re: 2520 Diesel Power in reply to Brad, 02-02-2003 13:44:11
DON'T !!!! 2520's are getting very collectable. If you want a higher horsepower tractor buy one. :-)
John
02-03-2003 06:21:12
Aside from asking what would you gain by doing so the answer would be yes. Boost the injector pump and install a turbo. I believe stock it was 61 pto hp. You could probably pick up 10+ hp which would be allright for pto applications but would alter your tractors hp to weight ratio for drawbar work considerably. My question to the scientific would be "Can the tractor use the additional 10+ hp efficiently?" Maybe in the tractor pulls? With extra weights but that mite put you in a higher hp/weight class
