420 transmission
Henry
02-01-2003 16:59:50
i am looking for a gear in a john deere 420 transmission part# At10746 or subs to #At16550 it may also be in a 40 or 430 with 4 or 5 speed. in the middle of a restoreation drained tranny only to find bearing rollers laying in bottom by drain plug. opened top and found sripped gears thanks for your help
Ray
02-01-2003 17:12:38
 Re: 420 transmission in reply to Henry, 02-01-2003 16:59:50
I found out that on some of those 420's the part
number doesn't mean much.I bought a double gear
with the exact part number I needed,and it was
different than the gear I needed.It took me a month and a lot of agrivation trying to explain
to parts guys that the gear I needed was a double
gear with a 1/2 inch space between the gears,and
the one they had with the same number there was
no spacing between the gears.Finally found one
in KY.the older and newer 420'S are different.
