Filter Head removal
52 B
Frank, Tx
02-01-2003 10:25:10
Can the Filter Head be removed without removing the crankshaft? So far, I have removed the pistons/rods to gain access to all the oil line fittings. By reaching through the #1 cylinder hole and the crankcase cover, I have been able to get one oil line loose. As expected, the pipe thread to tubing fitting adapters turn in the filter head when I try to loosen the tubing fittings - which requires trying to fit two wrenches onto something that I cannot see, or seem to get the wrenches on. Are there some special tools or tricks that I can use, or should I bite the bullet and remove the crank? Any thoughts or ideas would be appreciated.
mark mistie
10-07-2006 05:11:04
 Re: Filter Head removal - 52 B in reply to Frank, Tx, 02-01-2003 10:25:10
if you remove the rod caps and slide the block forward with the pistons and rings in it you can get to it from the front fairly easy. saves the agravation of trying to get to it without being able tu see what you are doing.
Mark
Dave K.
02-02-2003 17:12:11
I got my fittings off in there just through the crankcase. I did not remove the rods and pistons although I was thinking of removing the rod caps. You need short wrenches and a lot of time and, as Cloony says, your arms and hands will heal up soon!
Daqve
Clooney
02-01-2003 13:51:08
Frank, you should be able to get it out but it won't be easy working in there. You will have to use short wrenches & shinny arms. Once all the lines are loose you will have to pull the filter outlet tube from the bottom. Make a tool to go in the tube side holes, [an old wire pail handle works good] then use a pipe or other heavy object to hit downwards on the tool to pull the outlet tube out. Once the outlet is out you can remove the filter head bolts from the bottom. Good luck & don't worry your arms will heal in no time.
