730 pto
karl
01-31-2003 19:21:42
Just bought this 730 gas, its really nice but the pto case was full [4.5 gallons] of gear lube smelt like gear lube anyway. Manual calls for 4.5 quarts of 10 weight. I think maybe the seal from the transmission may be bad. I don't know this far a fact but I am just guessing. Is this possible? And if it is possible, how hard would it be to fix? Please advise.
Clooney_slow loading picture_
02-01-2003 02:31:50
 Re: 730 pto in reply to karl, 01-31-2003 19:21:42
third party image
Karl, you're guessing pretty good. That seal [see red arrow] is more than likely leaking trans gear oil into the PTO housing. [very common]
~It isn't the easiest of jobs as the whole rear housing has to come off the tractor. It is very top heavy so use care [& chains] when removing] it. Be careful pulling the hydraulic lines from the housing as they bend & distort easily & don't usually come out without a little finesse.
~The problem is,.... not only is the seal leaking [check the pump bushing & clutch drum shaft for wear also], but there is a very good chance that the lined PTO clutch plates are de-laminating due to the gear oil effecting the bonding [very common & expensive].
~You probably should disassemble the PTO clutch & inspect the plates for de-lamination & wear & possibly the PTO brake is also worm.
~I have some pictures of the PTO at different disassembly levels so let me know if you need some additional pictures. I strongly suggest a manual if you are going to remove that rear housing & go into the power shaft clutch. It isn't rocket science but there are a lot of settings & adjustments that need to be watched & set during re-assembly.
