430 power steering and lights question
Bguy
01-31-2003 18:40:04
Did 430w's with power steering have front lights on them? If so how were they mounted as the pump is right where the front light bracket needs to be on the right hand side. I don't see any alternatives in the parts book. A friend of mine has one with the lights mounted on the fenders but I supect this was not factory.
Wayne in Tn.
02-01-2003 06:43:57
 Re: 430 power steering and lights question in reply to Bguy, 01-31-2003 18:40:04
BGuy, to add to Henry J and c cue...I just sold a 430 Lp with power steering. Yes, they could have had lights. It takes a special bracket for the right side. It is listed in the PC 505 parts book. If your tractor is below serial # 158074 then it will need bracket # T11042T...If the serial number is 158075 or above, then it will need bracket # T12268T. Likely this is a rare piece, but some of the parts dealers might have it, such as John Shepard.
Bguy
02-01-2003 07:00:57
 Re: Re: 430 power steering and lights question in reply to Wayne in Tn., 02-01-2003 06:43:57
Thanks! That's what I needed to know.
Henry J
02-01-2003 05:26:22
BGuy
The right headlight is mounted on the fromt in the same manner as the left headlight. It fits nicely in front of the power steering pump.
c cue
02-01-2003 04:22:47
the front lights were mounted to the radiator surport and the hyd pump was mounted in the front of the engine looks like someone added the pump along the way hope this helps
