John Deere B Pistons
Dinglebery
01-31-2003 15:56:45
I have a 1944 B that I have new rings for. I'm not sure they are correct. The pistons measure 4.625 inches diameter.. When I put the top ring into the cyclinder the gap is about .250 inches. Is this gap correct or should it be smaller? A machine shop ordered them for me. I have only done this one time before.
Dinglebery
02-03-2003 20:45:20
 Re: John Deere B Pistons in reply to Dinglebery, 01-31-2003 15:56:45
Thanks for all the help..The pistons are .45 oversize--have rings ordered
gwh
01-31-2003 19:30:26
Hey Dinglebery, Can you get a part # off those pistons and are they castiron or aluminum. gwh
Dinglebery
02-02-2003 20:35:49
 Re: Re: John Deere B Pistons in reply to gwh, 01-31-2003 19:30:26
I'll check and see if a number is available.
Clooney
01-31-2003 16:19:28
Dinglebery, well, The rule of thumb is .003"-.004" ring end gap per inch of cylinder diameter. So you either have the wrong rings or your cylinders are worn pretty bad where you are measuring. YOU MUST fit the rings to the TIGHTEST point in the bore that the rings run in. Use the piston & push the ring to the bottom of the bore & re-measure the end gap there, if still too high you need different rings.
John T
01-31-2003 16:14:32
Dear Berry. I dont have any spec books, but YESSSS thats TOO BIG a gap. I thought standard bore was 4.5 ( 4 1/4 Unstyled, 4 1/2 Styled??) Maybe you have an oversize bore (4 5/8) and standard (4 1/2) rings, because you sure as *&^%$ cant run that much gap. Ol John T
