CLOONEY---RE: HOLE IN VICE GRIP JAWS.
JERRY J.
01-31-2003 10:57:51
WHAT TYPE OF DRILL BIT DID YOU USE TO DRILL IN JAW OF VICE GRIPS FOR REMOVAL OF PINS IN HOOD FASTENERS. THE JAWS ARE HARDENED. I JUST TRIED A COBALT BIT IN DRILL PRESS, AM NOT HAVING MUCH LUCK.
THANKS.....
Clooney
01-31-2003 13:47:18
 Re: CLOONEY---RE: HOLE IN VICE GRIP JAWS. in reply to JERRY J. , 01-31-2003 10:57:51
JERRY, I didn't have any problem drilling mine. I used an old set of grips that I was using as a welding clamp. Maybe I annealed it from the many heating & cooling cycles. If they are really hard you might just have to grind a slot in yours with a grinder.
CPeter
01-31-2003 14:45:21
 Re: Re: CLOONEY---RE: HOLE IN VICE GRIP JAWS. in reply to Clooney, 01-31-2003 13:47:18
Do you or anyone know where you can get new hood fasteners for Dubuque tractors? Correct Connection does not have them.
Thanks, CPeter
Larry
01-31-2003 14:55:25
 Re: Re: Re: CLOONEY---RE: HOLE IN VICE GRIP JAWS. in reply to CPeter, 01-31-2003 14:45:21
CPeter, I'm not sure as of today, but I got some from Deere dealer last year for my 430. They were pricey but you could get everything, the fastener with pin that you had to put in and also the receptacle that you screw pin in too. I probably am not even close on my spelling but I thought they were called haysuze fasteners.
Bus Driver
01-31-2003 17:20:01
 Re: Re: Re: Re: CLOONEY---RE: HOLE IN VICE GRIP JAWS. in reply to Larry, 01-31-2003 14:55:25
Dzus fasteners. Hot rodders use them some and perhaps Summit racing has them. Maybe used on some small aircraft also.
Clooney
01-31-2003 14:53:09
CPeter, Deere had then a while ago [can't say for sure if they still do] for around $7.00 apiece.
CPeter
01-31-2003 15:12:27
 Re: Re: Re: Re: CLOONEY---RE: HOLE IN VICE GRIP JAWS. in reply to Clooney, 01-31-2003 14:53:09
Thanks, I guess the old saying that when all else fails, try you John Deere Dealer is true.
CPeter
