4620, 5020 1000 PTO conversion to 540?
DB
01-30-2003 14:03:20
I have a 4620 and a 5020 tractor that sit much of the time while I use my junky old 4010 with hay equipment because it has 540 rpm PTO. Is there any way to convert the larger tractors to 540? I appreciate any advice.
scottAR
02-01-2003 19:27:37
 Re: 4620, 5020 1000 PTO conversion to 540? in reply to DB, 01-30-2003 14:03:20
Put a spline adapter on it and run the bigger tractors half speed.
Jeremy Hansen
01-21-2004 10:28:12
 Re: Re: 4620, 5020 1000 PTO conversion to 540? in reply to scottAR, 02-01-2003 19:27:37
I have a 4520 I have the same problem. I put an adapter 540 shaft on and it made the pto to long. So I have converted a few things over to 1000 pto.
Red
08-22-2004 01:06:42
 Re: Re: Re: 4620, 5020 1000 PTO conversion to 540? in reply to Jeremy Hansen, 01-21-2004 10:28:12
What is involved in replacing the PTO clutches on a 4520
RHA
01-31-2003 14:13:50
Hub-City makes a gearbox conversion from 1000 to 540. Pricey. Good to about 125 hp.
D.Lowrey
02-03-2003 20:25:41
 Re: Re: 4620, 5020 1000 PTO conversion to 540? in reply to RHA, 01-31-2003 14:13:50
How can I contact Hub-City? I would like to find a gearbox conversion from 540 to 1000 RPM for my boys two 730 D. so they can grind feed with my big grinder mixer that is 1000 shaft. THANK YOU David
JD70Jim
01-30-2003 20:13:07
It is a whole lot easier to convert the baler to 1000rpm. In fact, there are kits which could do this, when the balers were sold new. If you converted the baler to 1000 rpm, no work to the tractor would be needed, and highly unusual, shade tree engineered adaptors wouldn't have to be invented (by you) with possible less than acceptable results. Just my opinion of course.
Green Envy
01-30-2003 16:09:29
I have seen in a magazine where you can convert a 1000 PTO to 540 by bolting a type of gear box on the end of the pto. I can't remember the magazine or the details. Maybe you can do a search on the internet or maybe somebody else will have more details.
