Chattering in fan shaft
martin2
01-30-2003 07:52:23
I had to repair the ventaliator pump on my 51 b. after i started it i noticed that the fan shaft chatters every now and then. what the deal? Thank's mark
jason r
01-31-2003 07:49:42
 Re: chattering in fan shaft in reply to martin2, 01-30-2003 07:52:23
check the bolts that hold the fan shaft to the center support behind the radiator that supports the gen bracket and fan shaft. my 46 had that happen and it sounded like a chatter. it was the fan jumping up and down on the support. if you had been in there to take off belts etc. the bolts might have been loose.
Ralph
01-30-2003 09:29:33
The clutch facings in the fan clutch are disintegrating. Mine went last year and I thought the fan was hitting the shroud. By the time I would get up there to look, it would be as quiet as a church mouse.
martin2
01-30-2003 12:45:56
 Re: Re: chattering in fan shaft in reply to Ralph, 01-30-2003 09:29:33
please dont tell me i have to take this thing all apart agian.
Ralph
01-30-2003 18:17:31
 Re: Re: Re: chattering in fan shaft in reply to martin2, 01-30-2003 12:45:56
I'm afraid so, but I would have someone give you another opinion, as I had a long time JD mechanic do the critical work on mine. Send me an E-mail if you want to talk. There are four "dimples in a circular steel disk. When these contact other steel it makes one heck of a racket. Mine started this suddenly. If this is the problem, running it will only damage more parts. If it will make you feel better I can tell you some of the NTB moves I have made on mine.
