John Deere 720 Diesel, 3 point hitch
Kevin
01-29-2003 20:18:59
Is there any kind of adjustment to speed up the lowering of the three point hitch. We are using an 8ft. back blade and it's real slow in lowering. We checked the oil level, it's ok, and the oil that's in it doesn't seem to be to heavy. The service manual doesn't tell us much, but to refer to service manual sm-2022 for the power-trol and this we do not have. Any suggestion.
MIKE HANLEY
01-29-2003 21:08:58
 Re: John Deere 720 Diesel, 3 point hitch in reply to Kevin, 01-29-2003 20:18:59
Look behind the rigth axel just ahead of the P.T.O. lever that goes into the side of the casing. there is a long cxover nut. Remove and you will see a screw with a locking nut. loosen nut and screw the screw in. lock nut ant replace the cover nut. Do not confuse it with the single acting, duel acting screw for the remote cylinder. It looks the same, but is up behind the rockshaft.
Plant Doctor
01-30-2003 05:23:28
 Re: Re: John Deere 720 Diesel, 3 point hitch in reply to MIKE HANLEY, 01-29-2003 21:08:58
Mike: Don't you mean, turn the slotted adjusting screw OUT to increase the rate of drop?
MIKE HANLEY
01-30-2003 13:29:35
 Re: Re: Re: John Deere 720 Diesel, 3 point hitch in reply to Plant Doctor, 01-30-2003 05:23:28
OPPS!!! Yes out. Sorry about that.
Kevin
01-30-2003 17:08:19
 Re: Re: Re: Re: John Deere 720 Diesel, 3 point hitch in reply to MIKE HANLEY, 01-30-2003 13:29:35
Thanks alot, it works pretty good know.
