John Deere B clutch drive
keith
01-28-2003 15:31:55
what is the best way to change out the clutch drive disk? on the tractor or off and if on the tractor with the clutch engage or not?
Thanks
Gman
01-28-2003 21:12:30
 Re: John Deere B clutch drive in reply to keith, 01-28-2003 15:31:55
Keith remove the cover on clutch pulley,yo will see three bolts remove nuts then remove clutch plate and disk and you will be looking directly at clutch disc. To get this disk off you will need a puller also note the index marks on disk and end of crankshaft before removing after you have located these index marks pull clutch disk. Be sure to reinstall clutch disk aligning index marks if you don"t the tractor will shake the hood off. If you need any more help just yell. Gman
