720 axle clunk
Toby
01-02-2004 14:28:07
When I advance the clutch on my 720 diesel standard, some times there is a clunk in the right hand axle area. It is quite audible over the diesel engine. In either forward or reverse gears. Has any one have this problem befoer and can offer a e-diagnosis? I have made a point to ensure that the brake is clearly not on by the pedal.
Toby
01-03-2004 08:08:29
 Re: 720 axle clunk in reply to Toby, 01-02-2004 14:28:07
With your descriptions, I suspect that it is a worn wedge. I have had them off once, and I do recall that one side having a rounded edge on one of the channels. It didnt register at the time, but its that side I am certain.
Well I guess that means I get to start looking for a part (sometimes most fo the fun eh?) I dont imagine I want to damage my AXLE!!!!
BTW, -25C yesterday, and the pony and diesel started just great. Do that with an Delco.
Marty G
01-03-2004 03:33:10
My 730D was doing the same thing.The weel wedge lock needed just a little more tighting. give it a try and a little tap of the hammer wile tighting the bolts will hepl the wedge slide in tighter. Good luck.
Aaron
01-02-2004 16:28:51
One other thing to check if it has wheel weights make sure all the bolts are tight.
Aaron
Will P
01-02-2004 14:43:14
Check the wheel clamps that hold the rim to the center. I had the same problem on my 43B. There is a block that keeps the rim from spinning around the center. That is the cluck you probably are hearing.
Will P
Clooney
01-02-2004 14:42:14
Toby, the usual place of an axle area clunk is loose or worn wheel sleeves,or loose wedge bolts... If the key is worn or the sleeves are loose it will clunk like crazy when you change direction then engage the clutch..
~It wouldn't hurt to check the wheel to rim bolts either but that usually makes a creaking sound not a clunk.
~If the wheel & sleeves are tight on the axle & the axle & sleeve key & keyway isn't worn then you could have worn splines on the inner axle to bull gear splines [somewhat common on a well used diesel tractor]..
~There are other things that could be loose or moving but the above are the major causes of a clunking noise as the clutch is engaged..
[email protected]
buckeye al
01-02-2004 15:50:56
 Re: Re: 720 axle clunk in reply to Clooney , 01-02-2004 14:42:14
Not certain about the 720's construction but I have an A that had this same problem. With the splined hubs and pressed steel wheels it was not caused by loose hubs, wedge blocks or bolts. I found the cause to be the bull gears themselves. They are sand cast hubs with a ring gear pressed on & riveted fast with just three rivets. The three rivets are evenly space around the gear. They each hold two thick washers in place one on each side of the gear which acts like six round keys keying and holding the ring to the hub. I assume they saved money on the expensive gear metallurgy by using the cheaper cast hub. ANYWAY.... The washers had been hammered out of shape through the years. While not loose by any means the tractor would slip the ring on the hub quite regularly. I torched the rivets off, installed new rivets with new washers and this old A's clunks disappeared. Look where the other posts said to go first but if you don't find the problem there, maybe this is next. With luck, what I've described won't be your trouble.
