A Oil Pressure
TX Denny
01-28-2003 07:08:25
The spec is 10-15 psi. My A has about 21-22. Is that too high? Should I adjust it down?
Thanks,
Clooney
01-28-2003 07:19:10
 Re: A Oil Pressure in reply to TX Denny, 01-28-2003 07:08:25
Denny, that is plenty high. Before doing anything with it, run the tractor under load for about an hour or two in hot weather & see if it stays that high. Probably won't be that high after a good hard workout. If it does stay that high, lower it to about 15 psi or so. Make sure the gauge you are using is accurate in the 10 to20 psi range before doing anything else..... ..
TX Denny
01-29-2003 14:37:01
 Re: Re: A Oil Pressure in reply to Clooney, 01-28-2003 07:19:10
Thanks. I'll do that. Governor job turned out good. Thanks again,
