Has anyone bored an US B out .250 and put in early styled gas pistons?
Lon
01-27-2003 15:12:03
I've got a '38 B that I'm going to start working on. It's stuck now. It'd been sitting out in the trees for about 30 years. I figure the cylinders and pistons will be beyond salvage unless I bore it alot. Aren't early unstyled pistons about the same in all areas, except for being 1/4 inch larger? Would M&W aluminum gas pistons fit? Do you forsee any problems doing this? Thanks in advance. Lon
john
01-27-2003 22:47:13
 Re: Has anyone bored an US B out .250 and put in early styled gas pistons? in reply to Lon, 01-27-2003 15:12:03
I bored my unstyled B .250" and put early styled pistons in it. Barks a little harder, but runs fine. Posted a message here asking for pistons and got a real good deal on them.
John
Lon
01-28-2003 10:11:22
 Re: Re: Has anyone bored an US B out .250 and put in early styled gas pistons? in reply to john, 01-27-2003 22:47:13
John,
Did you put aluminum pistons, like M&W, in? gas or all-fuel pistons? Did you change carbs, like to a DTLX 34? Did you use the stock all-fuel manifold, or is there a gas one that would fit?
Thanks for any more info that you can give me.
Lon
