JD H Torque specs
Woody
01-27-2003 07:32:20
Back in Dec. I asked about the torque specs for an H. Donny-B said the head bolts were 96 ft/lbs except for the oil stud which was 180 ft/lbs. I'm wondering if that wasn't supposed to be 180 in/lbs. I know its a larger nut but it's on a hollow stud. I just want to be sure before I twist off the stud. Thanks.
dan_41jdh
01-27-2003 11:00:35
 Re: JD H Torque specs in reply to Woody, 01-27-2003 07:32:20
Woody, 180 ft-lb is correct, according to the I&T repair manual. (180 in-lb is only 15 ft-lb, not nearly enough to withstand engine compression loads.)
