DLTX Cleaning (Small Passage)
Randy O
01-26-2003 20:00:35
I read several archives about a small passage in the bottom of a DLTX carburetor. This passage affects the idle of the tractor and is hard to see. They say this passage is often overlooked. Where is this passage located? I want to make sure mine is clean.
Thanks!
Clooney
01-27-2003 02:31:30
 Re: DLTX Cleaning (Small Passage) in reply to Randy O, 01-26-2003 20:00:35
Randy, I tried to send you a diagram of all the DLTX carb holes that need to be cleaned but it wouldn't go through. Send me your E-Mail address & I will re-send it. That Roberts diagram doesn't show all the passages that need to be cleaned, just the ones that need drill bits to clean.
Randy O
01-27-2003 07:06:25
 Re: Re: DLTX Cleaning (Small Passage) in reply to Clooney, 01-27-2003 02:31:30
Try this address. Thanks.
[email protected]
Richard
01-28-2003 09:24:56
 Re: Re: Re: DLTX Cleaning (Small Passage) in reply to Randy O, 01-27-2003 07:06:25
Clooney, please send me the carb diagram to
[email protected]
Thanks
John T
01-26-2003 20:08:34
Randy, click on the link, its Roberts Carburetor's web page showing the passages for cleaning. I use the long #40 and # 53 aircraft bits he sells to clean out the passages. Good luck, Ol John T Nordhoff
http://www.robertscarbrepair.com/tip1.htm
