JD 50 and haybine
Tye
01-26-2003 18:13:30
Can my 50 run a haybine? If so what width would work best? Thank you for any help.
Dogdad
01-27-2003 08:08:21
 Re: JD 50 and haybine in reply to Tye, 01-26-2003 18:13:30
I wouldn't go any bigger then a 7ft. haybine.
I hooked up my 1209 once just to move it around the yard, won't do that again with the 50.
I have a JD #38 7ft. for my 50, it will cut hay all day long in 5th.
Dogdad
Craig M
01-27-2003 08:08:20
Tye Years ago my dad and I pulled a borrowed 9 ft haybine with a 49 A gas. We were cutting some pretty heavy hay and it would pull it. But it kept the A in a strain and at the end of the day we had to tighten the clutch on the A. This wasn't by choice but the A was the only thing we had to pull it. A 50 might do ok with a 7 ft haybine but it won't handle it with ease.
KenB
01-26-2003 21:14:30
I have a 9' New Idea mower conditioner that I pull with my 720 with no problems.I have also pulled it with my 60 with sucess.However I mow some ground that is hilly and with good heavy red clover and grass mixed hay it's a load for my 60. I sold my 50 3 years ago when I purchased the 720 so I can't say it won't pull it,but it would work the old girl hard.My 2 cents would be to use something a little bigger than your 50 or get a old sickle mower like a #5 or #8.I have a #8 that I use quite often latter in the summer when drying time isn't as much of a concern & the little 50 I had was great on the mower.
Larry D
01-27-2003 06:16:08
 Re: Re: JD 50 and haybine in reply to KenB, 01-26-2003 21:14:30
Tye in heavy hay a haybine would be pretty tough work for your 50. I have a 477 New Holland 7 foot
cut and in heavy first crop with brome, clover alfalfa mix I use the 2630 but in second crop I can use the 520 with no problem. I had pto problems on a 520 from pulling the haybine, it
was a expensive fix so now I am trying to save it
a little bit. A number 5 , 8 or 38 sickle mower
is alot of fun with a B ,50 or 520 and will get the job done but the hay will take longer to dry
unless you ted, crush or crimp. Good luck with your 50.
Larry D
KenB
01-26-2003 21:13:41
SamH
01-26-2003 20:53:43
If the hay is heavy, a 7 footer will give the 50 all it wants. I believe it is around 32 HP. I once saw a neighbor try to pull a 9 footer with a 42 HP tractor. It was overloaded most of the time.
John T
01-26-2003 20:24:10
Tye, like so many tractor questions, yours depends on how tough and wet and thick and type of hay. Real thick heavy wet hay would pull the *&^%$ out of a 50 with a 9 ft haybine, but in not overthick and good dry hay, it would do a nice job with a 7 ft. Other factors to make her pull better are a good sharp knife and use when shes nice and dry. (A lower gear may be necessary in heavier hay with that 50) Of course, you could hook her to a 9 ft and get the job done (maybe not in 4th gear) and Im sure people have, Im just talking in broad general terms that a 9 ft would be a hard pull on the old girl. I use a 720 on a 9 footer and in the first cutting in heavy hay, thats a good load. Ol John T
Chris
01-26-2003 19:10:35
I would say yes at least a 7 maybe a 9.
