5020
Bill Wilson
01-26-2003 17:37:28
Is a JD 5020 worth owning? What is one in good shape worth? It has 3-point and 1000 rpm pto. Canopy top and adjustable front with duals. Tires are 10 ply, but in bad shape. thanks
Green Envy
01-26-2003 20:19:59
 Re: 5020 in reply to Bill Wilson, 01-26-2003 17:37:28
Yes they are. 5010/5020/6030 tractors go for the same price or lower as 4020s. You can get more iron and horsepower for the same money with a 5020. I come from wheat country and most of the farms around here had one. They were a blessing to us out here because it allowed us the stop using crawlers. My grandpa replaced his IH TD-14A with a 5010 back in 1964.
We bought another 5010 3 years ago for runing an auger and grinder/mixer. It has 7,000 hrs on it and has not given us any problems. They are good, long lasting, and in my opinion one of the stoutest tractors JD ever made. The only complaint I ever heard about them is the noise when you are inside one of them tin cabs. If you don't plan doing loader work or using 540 pto impliments then I would look seriously consider the 5020. Ecspecially if you plan on doing some tillage.
The 5020 was the King of the New Generation tractors during its time and owning one would be like owning a JD 830 or R.
DTM
01-26-2003 17:49:42
This is a really big tractor, heavier than modern tractors of the same HP. As for worth owning, it depends on what you want to do with it. The 1000 PRM PTO does restrict some applications, and this is a big tractor for just snow removal or brush hogging. It is cool as a collector tractor and the rear end is so tough that I have seen conversions with 300 HP cummins and Detroits. They tend to go for a little less than 4020's and the like. I have seen good ones advertised for $4,000 to $5,000 which is unfairly cheap to such a good tractor. The little tractors increase in price as they get older and the big ones depreciate. just my $0.02
