G plugs?
JD G GUY
01-26-2003 13:25:18
whats the best plug to run in a G, I prefer Autolite plugs as i havent had good experiences with champion plugs in my B ( big difference between old autolites and new champions in an unstlyed B) I would like something a little hotter than stock because its using some oil.
Jack
01-27-2003 11:05:28
 Re: G plugs? in reply to JD G GUY, 01-26-2003 13:25:18
I use C86 AC plugs in my G and have never had a problem with fouling.
John T
01-26-2003 14:35:00
Hey G Guy, I cant answer not knowing the year, HOWEVER, I will say in general, in Unstyled Tractors like A's and B's, I prefer Autolite 3077 which are the hotter side wire electrode type plugs as opposed to 3076 which I believe are the normal recommended plug in Autolite. In Styled A, B and similar sized early numbered series, I prefer Autolite 388, which are again a heat range hotter than 386 called for. This is more for light duty or parade use, but if you work them hot hard and long at loads under temperature, the the 3076 (Unstyled) or 386 (Styled) is probalby better if the tractor is in decent shape and NOT an oil burner, if it is, I use the hotter range. The tractors and plug recommendations are more for hot and loaded, but light use or parades or oil burners can cause oil or fuel fouling because theres not sufficient temp and pressures to keep the plugs burned off clean and that nice gray color we all like. Ol John T Nordhoff
