JD 2010 Power Steering (or lack of)
Rod Schobert
01-26-2003 08:43:47
I have a 1964 JD 2010 diesel with power steering, no 3-pt hitch and no remote control hydraulics. Problem is the power steering control valve is NOT getting any oil from the pump. Pump appears to be in perfect condition. Manually turning the pump (on the bench) oil flow is blocked by flow divider from going to the steering port. I can't see a problem in the flow divider and everything looks right with the manual. Trans filter appeared to be OK. What am I missing?
HTR
01-26-2003 11:15:34
 Re: JD 2010 Power Steering (or lack of) in reply to Rod Schobert, 01-26-2003 08:43:47
Are you sure the pump is turning, when it is installed in the tractor? Is the pump disconnect collar splines good, and ingaged? Does the PTO work? If not, the splines could be bad in the pressure plate.
Elton
01-26-2003 10:43:43
I have 2010 THAT REQUIRES ME TO REMOVE AND CLEAN OR REPLACE THE HYDRAULIC FILTER ONCE OR TWICE A YEAR. THE POWER STEERING IS THE FIRST THING TO LOSE FUNCTION. HOPE THIS HELPS.
