855 question
Bob
01-02-2004 12:06:09
A friend of mine has a little 855 diesel (three cylinder), and he asked me today if I knew what a certain knob on his tractor was for. Told him I'd ask the experts. This knob is located to the left and below the seat, just in front of the rockshaft for the three point. The knob is about 2-1/2 to 3 inches in diameter, oriented so that the knob is to the rear of the tractor, and it just says "OPEN" and "CLOSE" on it, along with an arrow or two. Can anybody shed any light on what it does?
Thanks!
F-I-T
01-02-2004 12:43:24
 Re: 855 question in reply to Bob, 01-02-2004 12:06:09
Bob:
I have an 855, but it just left with my daughter, so I can't even take a look at it. I think the knob to which you refer is to control the speed at which the rockshaft drops. Closing it completely will trap the oil in the rockshaft lift cylinder and keep the rockshaft locked at that the present position. Gosh, I hope I'm right, because I can't even find the operator manual right now, and the service manual is less than clear on it's function.
Frank
Mike OH
01-02-2004 12:38:41
Hi Bob - I've got an 855 also and just went out to the barn to take a look. Almost forgot about that knob being there; never had a reason to use it. It is used to control the speed of drop of the rockshaft. If you are using a heavy implement, you can adjust the knob to allow it to drop slower than it would if set for a lighter implement. As a word of caution, to prevent damaging the tractor, do not raise the rockshaft when the lock valve is closed. HTH
Mike OH
