Flushing Crankcase and Transmission
Dave in Ohio
01-26-2003 07:04:09
What product and how much should I use to flush the crankcase and Transmission on an Styled AR.
Book calls for distillate to be used but that is long gone as far as I know.
Thanks
Henry J
01-27-2003 06:28:26
 Re: Flushing Crankcase and Transmission in reply to Dave in Ohio, 01-26-2003 07:04:09
Dave
My theory, which has gotten my down the road a ways, is that if it ain't broke, don't fix it. I might try a flush in a trans if it has the milky crud trying to oose out after the oil runs out. I believe in changing and replacing with the right kind of good stuff and checking the consistency of it after using enough to get hot and circulate well. If your engine has been run for a million years without changing, you may have to change the oil more often initially until it clears up.
ChuckW
01-26-2003 17:12:05
the inside of the case is painted, so I would stay away from anything too harsh such as paint thinners. I would use spray gunk cleaner and flush with some diesel fluid, remove both plugs from the transmission case and the engine case drain plug and filter....
Dave in Ohio
01-26-2003 07:58:16
Thanks guys. This old girl just got to me in Ohio last Tuesday. It has been sitting in a barn in Manitoba, Canada for many years. Starts and runs great after new batteries, cables and plugs. I'll take your advice and flush the transmission with kerosene and diesel and hand clean the block.
tjs
01-26-2003 07:41:10
Dave,
Many old manuals will recommend kerosene or the like for flushing any fluid area....when flushing the crankcase, take the valve cover off and make sure that it is relatively clean. I have heard that if you flush a real gooey crankcase, you can open a hornets nest. Another alternative is to keep changing the oil [and **filter** - when changing the filter, make sure all of the parts are there--ie, top and bottom seals] with a lighter weight oil [don't over work/heat the engine too much] @ very frequent intervals...this will remove the heavier sediments and goo. At the first oil change, remove the oil pan and clean the bottom thoroughly [make sure you have another oil-pan gasket ready if the old one is toast]. If, under the valve cover is not too bad, then add 4/5 varsol and 1/5 engine flush to the crackcase. Just run the engine for about 5-7 minutes in a stationary position, then drain. For the transmission, replace the fluid with varsol minus the addition of one bottle of engine flush. Jack both [back] tires off the ground, secure tractor, start and slowly engage tractor in 1st gear @ low-mediun speeds for a couple of minutes [don't drive on ground]. This will help to circulate the solvent and free any goo. After you refill with proper fluid, clean the bottom of the tractors seal/gasket areas respective to the transmission to monitor for any future leakage...your next transmission change may come a little earlier than normal because not all of the older fluids were all removed with the flush...just gauge your usage to make the change...good luck
tjs
John T
01-26-2003 07:19:23
Dave, I use diesel fuel and plenty of it. I like to fill her (talking tranny here not crankcase) then give her plenty of shake rattle n roll (spin them big gears) lol then drain it and repeat it for a final flush. Then refill and I would also change the oil and filter. Ol John T
Clooney
01-26-2003 07:13:31
Dave, a 50/50 mixture of kerosene & diesel works good for the trans [about 4-5 gallons needed].
~If you have been using modern detergent motor oil in the engine, a crankcase flush isn't needed. In fact it can do more harm than good if it loosens crud that plugs the filter or gets to a bearing. If the tractor has been using non-detergent oil you should pull the crankcase cover & clean it by hand.
