Bruce, something went wrong with your measurement. You should have shown somewhere between 1-4 ohms. Showing � ohms is almost impossible. If the coil went open when hot it would have showed infinity not � ohms, if it was shorted out internally it still would have shown a little resistance. ~Are you using the correct scale on your ohm meter? You need to use the 1X scale or the lowest scale you have. If you are using a cheap meter that only has a K, or K & M scale it won't give you a usable reading. If you are using a digital meter use the lowest scale, 1X scale, or Auto scale. ~If you can't get a cold reading on your meter in the 1-4 ohm range [with the wires disconnected] you have a bad coil [I doubt that as it runs cold] , or a defective meter, or you didn't correctly zero out your meter, or you don't have a 1X scale on your meter. My suggestion would be to take your coil to your local auto parts store as they usually have a means to test coils there, or at least have a digital multi-meter to use. If your auto parts store can't help you, maybe your local Radio Shack can. ~Due to that coil getting extremely hot it might need that ballast resistor but you really should check the resistance to be sure. ~While at the auto parts store if it shows lower than 2 ohms you can buy a ballast resistor [the NAPA auto parts- ECH 1CR13 works good @ about $14.00]. ~Does your coil have any numbers, resistor recommendations, or voltages written on the can? ~Let us know how it turns out?
