JB weld on Radiator
Frank
01-25-2003 08:37:26
Have a rad off a JD D . The rad leaks beside the top plate and the cores, a line about 3" long. Took it to a rad shop, was told it could not be repaired. Read the article about JB Weld on YT. Any experiences. Does JB stick to both copper and solder. Will heat from rad cause it to come loose? Thanks
Jimbob
01-26-2003 17:07:35
 Re: JB weld on Radiator in reply to Frank , 01-25-2003 08:37:26
My "D" with rotten bottom plate of top tank still holding after 3 years of JB fix. Also "H" radiator core (3 places) "A" upper water pipe. All fixes over 3 years old....
Dick C
01-25-2003 10:19:42
Frank,
I contacted JB Weld about one year ago with a question as to the working temperature range of their product. They told me the product would work to 600 degrees. The key is to get a good, clean surface for the adhesive to bond to. It will not successfully bond to corrosion or dirt.
Dick
ChuckW
01-25-2003 09:01:50
anything would be worth a try if you don't want the expense for a core....I've always found the plate holding the cores gets rotten and the cores get rotten in the center cooling area...you might patch up for a while...
Frank
01-25-2003 10:24:18
 Re: Re: JB weld on Radiator in reply to ChuckW, 01-25-2003 09:01:50
This is what is happening, the plate is rotting, but the cores are still ok.
