A axle seals
Mark Birkby
01-25-2003 06:24:07
I need to find outer retainer rings #A3041R for a 1949 A #636942 that was my grandfather's. My dealer can get the felt seal, but this retainer is unavailable. Anyone know of anywhere to find this part or an aftermarket source? Thanks.
Menno
01-27-2003 00:16:33
 Re: A axle seals in reply to Mark Birkby, 01-25-2003 06:24:07
I don't know if you want to restorerd the A original or not.
I left the inner cone on the axe and removed the outside cone. The I put in a normal metric grease seal.
Menno from Holland
Ralph-WI
01-25-2003 20:51:58
I reused the ones on my A as they were in good shape. Pushed them out as the nut on the inside end of the axle was undone.
Ron Stephens
01-25-2003 16:36:34
Have some new old stock ones that I would like $25.00 each plus postage.
Stephens Farms
Ron Stephens
3328 Rice Road
Dunkerton, IA 50626
319-822-7348
Clooney
01-25-2003 08:25:51
Mark, I believe K & K [317-398-9883] has [or at least had] them.
Mark Birkby
01-25-2003 12:06:49
 Re: Re: A axle seals in reply to Clooney, 01-25-2003 08:25:51
I tried the number for K&K but it has been disconnected.
Clooney
01-25-2003 13:48:26
 Re: Re: Re: A axle seals in reply to Mark Birkby, 01-25-2003 12:06:49
Mark, it was working about 2 weeks ago as I ordered some parts from K & K. You might want to try their web site or E-Mail...See link below.
Clyde Scott
01-25-2003 06:58:44
Mark:
Well, You have hit upon an on going problem retoring these old tractors. I had the same problem with a B I was restoring a couple years ago.. to my knowledge, there are no after market retainers avaliable. I found mine at a salvage dealer. I think is was Sharps. This is the only place you will find these retainers. Maybe someone else here has a source for repo ones but I have never heard of any.. Good Luck and congratulations on having your grandfathers old tractor.. BTW, if anyone needs a set for late styled B, I think I have an extra set avaliable.
Clyde Scot- Moultrie, GA.
