35 B starting update
Jak
05-16-2006 07:27:59
The float stuck in the carb but a little tap unstuck it.I started the B twice yesterday and tweaked the high and low screws.She pulls good and idles low but not as smooth as I would like.It is not a uniform putt putt but that might be due to a repaired stem of some sorts.I ran it for a couple of hours hoping to get it running as best I can with what I have to work with.I'll tinker with it this afternoon some more.Thanks for the help guys.Jack(TN).
Glen in TX
05-16-2006 12:41:19
 Re: 35 B starting update in reply to Jak, 05-16-2006 07:27:59
I knew when you said it had fuel out the top it was getting too much fuel and something stuck. Why was it stuck? Just needle stuck in seat or is the float bent or bad rubbing on the bowl ? Rust build up in bowl? Worn float pin or not aligned and centered? Wrong float? It may need more tweaking inside later. I should have mentioned before to make sure the float isn't getting heavy and fuel laden leaking. Can shake it to see if it has fuel inside or hold in a pan of hot water (not boiling) with pliers and you will see air bubbles spewing at hole if float has a leak. May just be the plugs got fuel fouled and it may burn off later or need plugs again soon but the throttle and choke linkage and gaskets on intake are a good place to start looking too. You will find some other free carb trouble shooting tests for H and other JDs also at jdhpubs.com and parts if needed from robertscarbrepair.com
Jak
05-16-2006 13:35:39
 Re: 35 B starting update in reply to Glen in TX, 05-16-2006 12:41:19
Thanks for the heads up Glen.I will see just how much this guy wants to spend.It started with a simple tune and it turned out not to be as simple as he or I thought it would be.She sure sounded good while my 16 year old son rode it all over the neighborhood.He absolutly loves hand crank Deere tractors no matter if it is an H up to a D.Bad thing about it the unstyled G is one of the most expensive and his favorite,I'll have to dig deep for one of those.
Glen in TX
05-16-2006 21:14:30
 Re: 35 B starting update in reply to Jak, 05-16-2006 13:35:39
Good luck with it. Sounds y'all are having fun anyway. Yeah, I'd still like to find the 38 G #4952 that my grandpa bought new but afraid of what they might want for it when and if I do find it.
Ben E.
05-16-2006 07:56:01
Hey Jak
Could be sucking air around the throttle shaft. Check this by spraying some W D 40 around the throttle shaft while idling if that changes the idle you probably need to replace the throttle shaft bushings.
Good Luck
Ben E.
Jak
05-16-2006 09:06:21
 Re: 35 B starting update in reply to Ben E., 05-16-2006 07:56:01
Thanks,I'll check that.Jack(TN).
