John Deere 720 Diesel with Pony Motor
Patrick Schley
01-23-2003 19:35:44
I'm considering the purchase of a John Deere 720 with a pony motor. I have been told not to buy it because you can't find parts for the pony and they are nothing but trouble. Also because it's a diesel and will not be used other then show, the motor can't take the stress of lack of work. Is that true?
Shane
01-26-2003 09:31:01
 Re: John Deere 720 Diesel with Pony Motor in reply to Patrick Schley, 01-23-2003 19:35:44
Patrick what is the serial number of this tractor.
Clooney
01-24-2003 14:02:10
Patrick, if you have other Deere's to play with & really want a Diesel, the 720 pony is a good one. If this is your first Deere or will be your only one, you might want to find someone in your area that has both gas & Diesel Deere's & see if they will let you drive them & play a little to see if you really want the Diesel.
~The 2-cylinder pony start is fun tractor, & is a good worker but as a light play tractor probably wouldn't be at the top of my list. There is more maintenance involved with the pony & the Diesel is hard to work on & very expensive when you do.
~The 2-cylinder Diesels are not the greatest play tractors unless you have something for them to do, they are heavy, can slobber black oily fuel if not in perfect condition, or if not worked, are quite noisy if used around the house or near other peoples places & tend to leave little puddles of black oil that your small animals can't resist tracking around. They can also fill your barn or garage with black soot if started in the building & if you have other restored vehicles in that area without covers will make a mess.
~The pony start is a good reliable system if used correctly, is a valued asset if the tractor is used in cold weather & sounds great when spinning up the big engine. The down side is, it is costly to repair, runs out of fuel at the worst times, is real costly to repair if it breaks, & can be a pain to work on. My choice would be a pony if the tractor is used all day on one or two startings, must be used in freezing weather, the Diesel is worn & a hard starter, or you need extra room on the platform [the pony battery box is smaller],,,,My choice for a play or chore Diesel that gets started many times in a day, isn't used in sub freezing weather, is used for light utility work, or is likely to be started many times in a day [or week] would be the electric start.
~The pony start 720 [or even the electric start] Diesel is a heavy tractor that doesn't haul well on light trailers, or with light trucks & will leave deep ruts in your yard.
~If the 2-cylinder sound is what you are after, the 2-cylinder Diesels don't sound nearly as good with a straight pipe as the gas 720, & sound like a barrel full of rocks falling off a truck when started in cold weather. I still like my 2-cylinder Diesels & like to hear the old 2-cylinder Diesels when working, but for just unloaded driving around would rather drive a 70 or 720 gasoline.
~If you decide to get that 720D, you really should also get something for it to do. Those Diesels like to work & just idling them around in cold weather is hard on them, most I have won't even get to 170� if just idled around [even with a new thermostat & the front grille covered]. To prolong engine life & burn out the crankcase moisture you should put them to work on a dyno, baker fan, PTO load, or other work producing load.
~When looking at that 720D you are asking about, pay special attention to the flywheel cover bolts & if they look like they have been removed in the near past or there is any knocking noise coming from the flywheel or clutch area be suspicious of worn clutch driver or flywheel splines [a very common & very costly problem on the 2-cylinder Diesels]..... ..... ...
jeff stacey
10-25-2005 06:13:05
 Re: Re: John Deere 720 Diesel with Pony Motor in reply to Clooney, 01-24-2003 14:02:10
i have a deere 720 diesel that is blowing black oily fuel on whoever is driving it. do you know what the problem may be???
THANK YOU
JD Ol'timer
01-24-2003 17:53:10
third party image
I agree with everything Clooney said.. the 2-cyl. diesels need to be worked and are very expensive to maintain unless you have the know-how and means to do-it-yourself. Mine has been sitting for 2 years now and has been to 2 tractor shows (local) and both times the pony motor failed to start at the shows (very embarrassing!).. I would recommend a 60 series (60/620/630) gas if you want it for shows or just to drive, you'll be better off in the long run to go that way, but the final choice is yours. Just remember that whatever you have to put in it financially will probably not be recovered when you sell it.
G Taylor
01-24-2003 18:29:51
 Re: Re: Re: John Deere 720 Diesel with Pony Motor in reply to JD Ol'timer, 01-24-2003 17:53:10
She looks pretty good. I'll bet the original owners "lost" the original pto cover and fenders. They likely couldn't see any problems or reason to drop the price because it "runs good",and cause who needs them shields anyways. We have had problems at this year's show from the trucking shaking dirt/rust loose in the 70D's starting engine fuel system and the 50's plus a helper leaving the starting engine ignition switch on the 80. We have also had vandals load the fuel tanks with dirt and corn cobs in previous years.
G Taylor
01-24-2003 09:06:21
The people who complain about starting engines are those who never owned one and pass on tall tales. Or crude hack owners/operator/maintainers of starting engines. We have Dad's 70D standard he bought new in 1955,a 720D standard and a 80. Wouldn't consider a electric start at below freezing temps.Have to purchase some HD batteries every few years too. Ever add the price up over 20 years? Any problems come back to the ignition being left on/fuel not turned off, dirty/old fuel or operators with no clue who won't purchase/read the manual. Imagine the extra stress on the clutch/drive train engaging the starting engine with the diesel still under compression. As for the diesel on parade duty. Make certain the injectors are freshly service and breaking up the fuel. Install the high temp thermostat and cover the rad if she runs below 190F. If it's an odd job for a couple of minutes we grab the 40,one of the 50's, the 60 or the gas 70 row crop.
John T
01-24-2003 06:35:49
Patrick, I have owned and used them diesel and gas, pony and electric start, and I agree with the other posts in that its a personal choice based upon what you want to use the tractor for. If you want a diesel tractor that needs to start in extreme cold climates, theres nothign better than the pony provided you get in in good shape and properly maintain it. Their exhaust heat warms up the intake air passages of the diesel, and provided you dont run out of gas, she will crank and free and warm up the diesel till she starts where an electric start may fail in cold temperatures. One reason the ponys caused trouble was the failure of the operator to allow them to warm up sufficiently and then a brief cool down as opposed to jumping on and startign and immediatley cranking the diesel with them then shut down and they never had time to heat up to rid themselves of moisture and carbon and got all sticky and carboned and varnished in the combustion and fuel areas. The diesel, especially with a pony, does require more preventitive maintenance than a gas trwctor and the ponys can be extremely expensive to overhaul depending on what their problem is. Still, theres nothing neater than firing and warming up that loud screaming pony, pull that compression relief back and let her lug down to crank that big diesel engine, get the diesel free and spinning over, and THEN dump that compression release and hear the old girl fire up wooooo ooo hooooo ooo. Good Luck, I hope you get it (its your money lol not mine) John T Nordhoff in Indiana PS I also had a 70 Diesel, Wide Front, Good Pony Motor, exc. condition which I sold in the eighties at Linton Indiana under $2000 and Ive kicked myself ever since. I dont even have a picture of it grrrrr rrrr
Blksmok
01-24-2003 05:18:51
Patrick...It depends on how you intend to use the tractor and if you like, or are annoyed by, the constant required tinkering with the pony engine. If you want to jump on the tractor, turn the switch, hit the starter and go, this is probably not a good tractor. Also, unless you're in love with diesel engines or intend to use it alot to have the fuel consumption become a factor, a gas model is more user friendly. I have both gas and diesel 720's and if I'm in a hurry I head toward the gas model. If I'm going to start it and run it all day, then I head for the diesel model. With the pony start diesel model you've got two engines to maintain. It's a personal preference deal.
Ty
01-23-2003 19:49:28
Well I have a 70D pony start and the pony is not bad if you know what you are doing. Use top quality oil and fuel. I put a inline cleanable fuel filter and it hasn't failed me yet. You have to let it warm up properly and treat it with respect and it will be good to you. The diesel would work if you have a few hills or drive around for a while once in a while, full throttle to keep things moving. Mine is used on the farm so she is worked hard. I have no complaints and there are always parts avaliable if you shop around. I say get it!
stuart martin
01-27-2003 10:27:25
 Re: Re: John Deere 720 Diesel with Pony Motor in reply to Ty, 01-23-2003 19:49:28
the problem with pony motors is that they run 7000 rpms and no one lets them warm up or cool off before they use them and when they are done
