Fan shaft
john n
01-23-2003 19:25:27
looking for gear for end of fan shaft for 1948 jd b. any suggestions are greatly appreciated!
Clooney
01-24-2003 14:51:28
 Re: fan shaft in reply to john n, 01-23-2003 19:25:27
John, as John T said they really should be replaced in a matched set. ~I have just replaced single gears before without a problem but if you go the single gear route be sure to use a small grinder & remove any gear tooth wear high spots & flashing on the tooth ends & don't set the backlash too tight. They will probably howl some for a while but will usually calm down after a break-in period.
~You shouldn't have a hard time finding a gear for that "B" as most tractor scrap yards should have one..... .
John T (matched is best)
01-24-2003 06:48:56
Dear John n, You may want to consider buying BOTH a matched set of governor PLUS fan shat bevel gears (even if its used, still a matched set off the same tractor) because if they are badly mis matched, you will have a noisy whiny governor. The shim gasket thicknesses both under the governors bearing end cap and the fan shaft mounting hub is how you set the backlash, heel and mesh of the 2 gears to avoid whineeeee eeeee. They need to be set right and its far better of they are a matched set. Good Luck, Ol John T
Easydoes it
01-24-2003 06:07:46
May have a spare at 205-552-2678. easy
Ron Stephens
01-24-2003 05:01:42
Have a new old stock gov/fan shaft set AB3706R that I would like $140.00 plus UPS for.
Stephens Farms
Ron Stephens
3328 Rice Road
Dunkerton, IA 50626
319-822-7348
