1971 JD 140 H3 Controls
Fred in Weare,
01-02-2004 07:43:26
Ok, so I'm waiting on my OM for my H3. To my left, sitting on the throne, are three levers. To my right is a single lever for the hydrostatic tranny.
Can someone give me an "H3 for Dummies" description on their function? I though I had the float in neutral, but whenever I go into forward, from revers, the blower drops.
Thanks!
Fred
Bob
01-02-2004 08:23:57
 Re: 1971 JD 140 H3 Controls in reply to Fred in Weare, NH, 01-02-2004 07:43:26
Levers on LH side...
Extreme left lever... operates LH front couplings.
Middle lever... operates RH front couplings... used for snowblower lift. Hook couplings up so blower lifts when lever is pulled back. Lever will spring return to neutral... snowblower should then stay up no matter what. Push forward and blower drops, again lever should return to neutral. Push EXTREME FORWARD... float position, and lever way stay in that position. The position of the hydrostatic speed contol lever should have no effect on the blower falling from the raised position. If the blower will not stay up when the middle lever is in the neutral position, my best guess would be a problem with the springs and detents in the valve, or one of the three valve spools, or one of the three levers being stuck in a position other than the center, neutral, position. Are any of the three levers "sticky", or can you clearly feel them being returned to the center neutral position by spring action? If any do not return exactly to center, that can affect the function of the whole system. Of course, the exception is that the middle lever, if pushed extreme forward, will remain there, and the blower will "float."
RH lever... operates the built-in cylinder and rockshaft under the tractor frame for mower, tiller, or sleeve hitch lift.
