Radiator removal on a 60
AlbertoV05
01-22-2003 13:36:25
I've got a late 60 with power steering and need to get the radiator out to repair/replace the leaking core.
Would it work to remove the grille, air cleaner assy, water pipes, etc. And then remove the steering wheel from the shaft; seperate the steering worm gear housing from the pedestal and slide the steering shaft and worm gear housing out the front as a unit?
I'm hoping this is possible and would give me the clearance to get the radiator out.
If it is possible, would I have to check endplay/backlash on the steering system when I go to reassemble? I don't have a dial indicator to do this.
Al in Iowa
John Van Valkenburgh
01-23-2003 01:19:56
 Re: Radiator removal on a 60 in reply to AlbertoV05, 01-22-2003 13:36:25
I installed a new radiator core on my model 50 a few months ago and I believe it will be similar to your model 60. I did exactly as you perpose. The steering wheel is removed from the steering shaft and the worm-gear section is unbolted from the steering gear (4 bolts). The shaft is then pulled forwards through the hood. I did not attempt to measure endplay/backlash as nothing really changes as long as you reassemble with the same number of gaskets/spacers etc.
After removing the hoses, the radiator is held in place by two rather large bolts directly underneath the lower tank section. Overall the radiator is pretty heavy. A two man job to remove.
The radiator is comprised of upper and lower "tank" sections with the core bolted in the middle. Lots of little bolts to undo. I had around half a dozen snap on mine. Take your time.
I ordered a new core and forgot to order two gaskets. The gaskets for the upper tank and lower tank were identical.
Be prepared to mix a lot of antifreeze! The 50 holds 7 (count 'em 7) gallons. I think the 60 holds even more.
Best of luck,
John
Ken RB
09-28-2006 07:45:45
 Re: Re: Radiator removal on a 60 in reply to John Van Valkenburgh, 01-23-2003 01:19:56
I know everyone is busy but this old man needs a little help.
I just bought a 1955 model 60 dual fuel s/n 6046775. I am in the process of reinstalling the radiator assembly properly. When I got this tractor the two large bolts were missing from the bottom of the assembly. I went to the Deere dealer in Lake city FL and the microfiche does not show two large bolts holding the radiator at the bottom. These bolts appear to hold the bottom tank to the frame. Can anyone tell me the size of these bolts?
Thanks to all, Ken
