430 compression test
Larry in Mi.
01-22-2003 09:33:04
I checked the compression on my 430 last nite, both cylinders were at 100lbs. what should they read? and if they're low what would you recommend? Thanks LS in MI.
Jack
01-22-2003 10:37:28
 Re: 430 compression test in reply to Larry in Mi., 01-22-2003 09:33:04
If your tractor does not smoke or use much oil then 100 psi is good for it.If both cylinders are the same than you should be ok.Later,Jack(TN).
