2510 Side Shields
John in Md.
01-21-2003 12:33:36
I saw a pair of shields on Ebay that are $145 and gaining.Are they always this exspensive? Are there repros or are they always this high. I need a pair but not that bad. Any sources or suggestions will be appreciated.
John in Md.
01-22-2003 16:16:15
 Re: 2510 Side Shields in reply to John in Md. , 01-21-2003 12:33:36
Final price was $250 plus shipping.About 3 times what I thought they would.Somebody really needed them.
7700
01-22-2003 04:23:33
Listen up and save your money!
I have a 2510 that I had restored about 5 years ago. I would not/could not find the shields that are very pricey.
What I discovered is that the top pins on the side shields are the same as a 4020...and probably the 3020 too. These pins are the same alignment as your 2510...only difference is the height of the panel. I had the body shop cut the panels from these 4020 panels down in height and spot weld the bottom angle bracket back on. Then you can drill out the slots on this bottom piece of angle to align with the pins on the tractor frame. 4020 panels are easy to come by at junkyards and are cheaper than buying 2510 panels. I can assure you that there is no noticable difference after you repaint the side panel. I did it and it worked.
John in Md.
01-22-2003 11:14:43
 Re: Re: 2510 Side Shields in reply to 7700, 01-22-2003 04:23:33
What about the rounded one over the starter.That's a one of a kind,not similiar to any others ,besides 2520[just as overpriced].
7700
01-22-2003 13:05:43
 Re: Re: Re: 2510 Side Shields in reply to John in Md. , 01-22-2003 11:14:43
The side shield "flexes" over the starter...I know what you are referring to but it is not a problem as you might think. I can't remember if we slightly bent ours or not...just have to play with it and see what needs done.
