38' B clutch
JDBert
01-21-2003 12:07:14
I asked this question awhile ago but jsut getting back to it. I'm doing a 38' B that had ruined the splines on the clutch. I got a .045 under hub from Denglers, which is fine fitting on the splines but comes in contact with the clutch before it gets in to place. The drive gear hasn't worked itself out the hub fits the splines like it should. So I did some measuring and I come to the conclusion that my hub has the splines cut backwards. Heres the measurements tell me what you guys think. measurements from flat surface, the first number is the new -.045 hub and the second is the old hub
from flat- flywheel side up 2 1/8 1 1/2
center hub to drive area -0.125 0.125
Total thickness of drive area 1.5 1.5
from flat- clutch side up 1.5 1.75
Hub to drive area 0.5 -0.1875
Sorry so long
thanks in advance
Larry806
01-21-2003 14:00:51
 Re: 38' B clutch in reply to JDBert, 01-21-2003 12:07:14
Looks like Nickie got another one That is the best place to STAY AWAY from I know of I know 6 people that have done business there all got shafted 4 were on his taper lock flywheel's I worked on one of them & had to call him he told me the guy didn't install it right if he did it by the directions they gave him with it! Of course NO refund or credit
