Gear Oil
Randy
01-21-2003 10:51:09
I know this question has probably been posted before, but I'm trying to find out which type of gear oil to use in the transmission on my G. I know the operator's manual says 90 weight, but should I go with this or use something else? The only thing I'll be using the tractor for is pulling some and mainly show, no farming. I want something that will run quieter and not worry about damaging the tractor in any way.
Thanks for any information.
DAve K
01-22-2003 16:35:27
 Re: Gear Oil in reply to Randy, 01-21-2003 10:51:09
I use multigrad GL-5 80/140 oil
Randy
01-21-2003 15:07:04
Thanks for the information guys. I'll probably go with the 140 since the only time I will use the tractor will be in warm weather.
Clooney
01-21-2003 14:47:30
Randy, for pulling you will give up a slight amount of power to the stickier 140 weight gear oil. Probably can't measure the difference though. ~If you are only going to use the tractor in the warm summer & for shows the 140 will be fine. For winter use it might be a little thick for sub 0� shifting....
Jack
01-21-2003 12:09:34
I use 140 weight in my 53 G.I had a little noise in third and 6th but that quietened it up considerably.I pull mine too,love them G's.
