Ray, John gave you good information in his presentation below & I thought you might like some wire colors & additional information. ~The first thing you will need is the correct regulator for you application. If you are keeping your tractor positive ground then you will need either a positive ground regulator or regulator rated to both positive & negative ground. Not all are, & some are just positive, or negative, but not both. ~Below is brief copy of what I usually send with return E-Mails for "how to" on 50 generator wiring�����. ~There are differences in the early & late 50 [over or under s/n 5014648] as far as wiring diagrams go, but for the purpose of wiring the generator they are pretty close. ~Mount the regulator solidly on the generator making sure it has a good contact to the generator frame [the regulator must have a good ground to operate]. ~Once the regulator is mounted on the generator, run a 14 gauge [ black], or [green] color wire from the regulator [F]or [fld] terminal to the generator [F] post {smaller of the two}...nothing else goes on either or these terminals or regulator damage can result. ~Then run a [white] color 12 gauge wire from the regulator [GEN] or [ARM] �could be marked either�.. terminal to the generator [A] post [larger of the two].
~Then run a [white] color 12 gauge wire from the regulator [BAT] terminal to the [ammeter] non-battery side stud. ~All loads [including the BAT wire from the voltage regulator to ammeter ] hook to the non�battery side stud of the ammeter. Exception is a cigarette lighter, that would hook to the battery side of the ammeter. When the system is put into operation, if the [ammeter] reads backwards just reverse the wires on the ammeter from side to side to get correct ammeter operation. ~If your regulator has an [L] terminal, the ignition & light feed [load] would hook to the [L] terminal on the regulator. So if your regulator has that [L] terminal you would run a [black] 14 gauge wire from the voltage regulator [L] terminal to the [BAT] terminal on the ignition switch, then run a jumper from the [BAT] terminal on the ignition switch to the light switch feed terminal. ~If your regulator doesn�t have that [L] terminal [most replacements don�t] then just run a 14 gauge [black] wire from the [ammeter] non-battery side stud to the ignition switch [BAT] terminal. & run another 14 gauge wire from the [ammeter] non-battery side stud to the light switch feed terminal. ~On the original early 50 [under s/n 5014647] �I think� (not positive though) the wire from the [ammeter] battery side stud ran from the [ammeter] to the big stud on the starter, but you can run it to the battery non-grounded side [the most negative battery post on a positive ground system]..Run a 12 gauge [white] color wire from the [ammeter] battery side stud to the big stud on the starter being careful to keep it away from the flywheel & sharp edges. ~On the late 50�s [after s/n 5014647 the wire ran from the [ammeter] battery side stud to the negative post on the non-grounded battery [2- battery system], or just the negative battery post if using a single battery, using the same harness as the rear lights. ~Once it is all together & the battery is installed & charged you must polarize the generator by momentarily jumping the [BAT] terminal on the regulator to the [GEN or ARM] terminal on the generator [if you see a spark it is polarized, if no spark, make sure you have battery power to the [BAT] terminal on the regulator. CAUTION: at no time run any power to the regulator [F] terminal or generator [F] post as severe regulator damage could result ~It usually helps to print these "how to's" out & take them to the tractor for immediate reference. Then keep a copy in the owners manual for future trouble-shooting.
